Tension Wire As Rafter Ties?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 06:46 PM   #1
tension wire as rafter ties??
Hi,
Has anyone used tension wires as rafter ties? Or aluminum perhaps?
My garage already have joists from wall to wall but I feel they are not enough. However, I also feel like a 2x4 by 20 ft will be too heavy, any alternative?
Wolfen is offline   Reply With Quote
Old 02-27-2011, 07:25 PM   #2
Experienced
Jackofall1's Avatar
Why do you think that you need rafter ties? As you already have the required joist's.
Edit --- Here's an article you might find interesting.
http://www.finehomebuilding.com/how-...llar-ties.aspx
Mark
Old 02-27-2011, 07:56 PM   #3
Because there are only 4 joists, garage width is 20 ft. There's also a new much heavier aircondition unit installed on top of garage which was I think was not factored in on the original construction of the garage. I've just bought the house recently.
Old 02-27-2011, 08:34 PM   #4
iminaquagmire's Avatar
Rewards Points: 338
Talk to a structural engineer as they will have the info you'll need for sizing cables anyway. Its possible however that what you have is perfectly fine depending on your roof construction and pitch and your climate. Rafter ties are stressed in a different manner than joists as they only keep the roof from pushing the walls out. They are not meant to be loaded and are only under tension. As such, just 2x4 material can work in even a northern snowy climate as the material can handle tension more than it can handle deflecting loads.
iminaquagmire is offline   Reply With Quote
Old 02-27-2011, 08:44 PM   #5
Climate here is usually warm... Los Angeles so, the warmer, the less need for rafter ties?
Old 02-28-2011, 07:22 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,... Correct,... No snow loads...
Old 02-28-2011, 05:00 PM   #7
There's also a new much heavier aircondition unit installed on top of garage.
Is the unit under the roof, supported by the ceiling joists or above the roof, out in the weather!
Old 02-28-2011, 10:24 PM   #8
my Central HVAC (huge one, for supporting 4 bedrooms) is above the roof. right under the the hvac spot (inside, in the garage ceiling) there multiple rafters to reinforce that spot.. is that enough? is this a classic "if it aint broken dont fix it" kinda deal?
Old 02-28-2011, 10:52 PM   #9
Registered User
Rewards Points: 526
From my library: http://www.eng-tips.com/viewthread.cfm?qid=105386
Pictures would be nice....... of the inside ties and rafters....
Gary
Old 03-01-2011, 11:21 AM   #10
I've used cables to pull in an out of plumb wall, but, since they sag according to the distance they span, a steel rod with threaded ends would be better in place of joists. If you re-use joists or add more, consider anchoring them to the rafters with bolts and toothed connectors. Correcting the cause of the sag would also need to take place
mrgins is offline   Reply With Quote
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
Replacing rafter ties Jim F Roofing/Siding 6 08-17-2010 10:20 PM
Making room up in attic Proby Building & Construction 7 07-31-2010 08:24 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
