Ten Ft Span Of J-channel - Should I Splice It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 02:59 PM   #1
Rewards Points: 150
Ten ft span of J-channel - should I splice it?
About to start installing beaded vinyl soffit on porch ceiling. There is a 10' span along the sides of the porch.
To allow for expansion/contraction of the J-channel, and also have nice looking corners, would it be better to splice it into two 5' pieces and force possible movement at the join instead of at the corners?
Or am I worrying too much?
NancyNGA is offline   Reply With Quote
Old 07-17-2012, 03:04 PM   #2
Rewards Points: 13,736
Since it comes 12'6" why would you cut it? Trim does not move like the siding does.
Siding trim can get nailed tight, it's the siding or beaded that is hung not nailed tight.
May want to concider using 1/2 J not 5/8" it that's what you have.
Old 07-17-2012, 03:35 PM   #3
Rewards Points: 150
Thanks, Joe. I just thought the J-channel moved a lot, too. Sure didn't want to splice it if it wasn't necessary.
Actually it's only 3/8" channel, made for the narrow 6" wide soffit with three 2" slats. (Certainteed).
Old 07-17-2012, 04:10 PM   #4
That J needs to be 1/2, I've never seen or heard of 3/8". The panels need to be able to move inside the J, if not it's going to buckle. Check it out, it should be slightly loose.
Old 07-17-2012, 04:55 PM   #5
Rewards Points: 150
This is the only picture I could find. They make J-channel specifically for it. And I checked it out---the panels do move in there. Thanks!
Old 07-17-2012, 06:29 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
3/8'' is the proper j for that panel
Tom Struble is offline   Reply With Quote
Old 07-17-2012, 11:43 PM   #7
the lady knows her vinyl carpentry
Old 07-18-2012, 12:02 AM   #8
I almost never use J moulding with beaded soffit, I use vinyl cove moulding that's made by Certeenteed.
It looks like cove from below but it has a track in it for the beaded panels to slide into.
Looks far better.
Old 07-18-2012, 06:44 AM   #9
plus you didn't know 3/8'' existed
that cove has a wider pocket then the panel is and the back of the panel needs to be shimmed for it to ''look much better''
Old 07-18-2012, 07:41 AM   #10
Rewards Points: 150
Exactly!
I just really like their beaded 6" stuff so much better than anything else I could find, that I decided to compromise on the channels. Maybe a mistake. We'll see I guess...
ETA: That's why I don't want the shrinkage come January to show little black holes at the ends of the mitered corners. Think I'd rather see a seam in the channel in the center of the run. Still inclined to splice it.
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
Help! Casings around window with integrated J channel? Learn2Build Remodeling 8 06-01-2010 05:10 PM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 04:41 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
