Is A Temporary Wall Necessary? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 06:04 PM   #1
Is a temporary wall necessary?
I have a back wall to my house. It is load bearing and I believe it may have a beam in it or at least headers above the 3 sliding doors across the back. I want to replace 2 of the sliders with some windows. I want to replace 1 slider with a new one.
I thought I could pull out the sliders and frame accordingly for windows and just pop in the new slider. A friend tells me I need to build a temporary wall to carry the weight. How could sliding doors be carrying weight right now? Is that possible? I guess the temporary wall isn't a bad idea, but is it necessary?
mjhaston is offline   Reply With Quote
Old 07-15-2012, 06:21 PM   #2
Framing Contractor
Not necessary at all. As long as you don't touch the king and jack studs. You can always close the opening from bigger to smaller, or put the new window or door in the same opening. Windows and doors do not support any load, the headers do.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
mae-ling (07-15-2012), oh'mike (07-16-2012)
Old 07-15-2012, 07:37 PM   #3
Rewards Points: 2,212
If you are going bigger then you need to support and redo the header.
mae-ling is offline   Reply With Quote
Old 07-16-2012, 12:25 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
I agree with Joe and mae-ling
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-16-2012, 01:20 AM   #5
Rewards Points: 502
Don't we all.
(If you had needed to put in a temporary wall, you would never have been able to open the sliders in the first place. Your friend needs to join a site such as this to learn a little more!).
tony.g is offline   Reply With Quote
Old 07-16-2012, 07:42 AM   #6
Makes perfect sense. Thanks everyone.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Temporary Tile Wall auntd Building & Construction 1 05-10-2008 10:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
