-   -   Is a temporary wall necessary? (http://www.diychatroom.com/f19/temporary-wall-necessary-150375/)
mjhaston 07-15-2012 06:04 PM
I have a back wall to my house. It is load bearing and I believe it may have a beam in it or at least headers above the 3 sliding doors across the back. I want to replace 2 of the sliders with some windows. I want to replace 1 slider with a new one.
I thought I could pull out the sliders and frame accordingly for windows and just pop in the new slider. A friend tells me I need to build a temporary wall to carry the weight. How could sliding doors be carrying weight right now? Is that possible? I guess the temporary wall isn't a bad idea, but is it necessary?
Joe Carola 07-15-2012 06:21 PM
Not necessary at all. As long as you don't touch the king and jack studs. You can always close the opening from bigger to smaller, or put the new window or door in the same opening. Windows and doors do not support any load, the headers do.
mae-ling 07-15-2012 07:37 PM
If you are going bigger then you need to support and redo the header.
GBrackins 07-16-2012 12:25 AM
I agree with Joe and mae-ling
tony.g 07-16-2012 01:20 AM
Don't we all. :)
(If you had needed to put in a temporary wall, you would never have been able to open the sliders in the first place. Your friend needs to join a site such as this to learn a little more!).
mjhaston 07-16-2012 07:42 AM
Makes perfect sense. Thanks everyone.
