Old 10-02-2007, 11:47 PM   #1
yummy mummy's Avatar
Default Temporary nail to hold drywall; what to do with it?
If I put in a couple of nails just to temporarily hold the drywall up in place, until I put in the screws, what do I do with the nails that I have put in?
Do I remove them and put in a drywall screw in its place, or do I hammer it in all the way.
If so, how would I get it to be slightly "dimpled" into the surface of the drywall. (If I don't have that special drywall hammer)
yummy mummy is offline   Reply With Quote
Old 10-03-2007, 12:15 AM   #2
Kyle Emerick
kemerick's Avatar
That is the way my drywallers did it and some of the time a framing (waffle) hammer was the closest thing around so it got used. Mudding will always cover the hole up as long as it is not too deep as then it will shrink and crack... and that will mean more coats if its a crater.
Hammering away sounds like the best and easiest way.
My constant project is my home which was built in 1947. I have remodeled almost all of it and am in the process of finishing off a 1000 square foot addition. Lars Construction got me up to drywall and I am doing the rest.
You can see many galleries of it located here under Galleries and then House.
kemerick is offline   Reply With Quote
Old 10-03-2007, 12:21 AM   #3
robertcdf's Avatar
You can use a 40D nail and any hammer to set it in just slightly... But dont break the paper
robertcdf is offline   Reply With Quote
Old 10-03-2007, 10:25 AM   #4
Thanks for the advice.
Can I just take the nail out and replace it by the drywall screw?
As I am afraid that I will hammer too hard and break the drywall.
Old 10-03-2007, 10:50 AM   #5
You won't break the drywall. Just smack it in with a smooth faced hammer till it's just below flush, don't use a waffle faced framing hammer.
Old 10-03-2007, 11:19 AM   #6
Thanks jogr.
From what I have been reading, they say that you need a special hammer to nail drywall, and I don't have that hammer.
OK, I am going to try and hammer it in, but I would rather take it out, and put in a screw since that is what I am using to adhere the drywall.
Old 10-03-2007, 02:09 PM   #7
They do have drywall nails, and any hammer will do. Set the nail and just put in a screw 1" away from it.
Ron
Old 10-03-2007, 03:06 PM   #8
Thanks Ron, I think I will do that.
Old 10-03-2007, 06:51 PM   #9
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Only use drywall nails to temporarily hold sheets in place. ONLY NAIL on the perimeter edges. Do not apply nails to the "field" of the sheet.
After you have the sheet screwed off, you can simply hammer the nails in.
- Build Well -
Old 10-04-2007, 12:40 AM   #10
Thanks Atlantic.
I'm glad you told me not to nail in the "field" of the sheet, because that is just what I was going to do.
I will nail only on the edges then, and then hammer through.
I will start this weekend, hopefully, if hubby goes out and picks me up a couple of sheets.
Old 10-04-2007, 08:38 AM   #11
YM, You obviously understand that in addition to "not" nailing in the field of the sheet, that you should, however, apply screws approximately every 16" in the field. I thought I would clarify that point even tho you probably understand that already.
Also: where vertical sheetrock seams meet (over studs), install your screws on each sheet end approximately every 6" to 8".
- Build Well -
Old 10-04-2007, 10:26 AM   #12
yummy,
When you say "hammer through" I hope you don't mean it. Just hammer the nail head till it's just below flush with the exposed surface of the drywall. If you look or feel across the drywall you will have just a light dimple from the hammer if you've done it right. You'll pick it up fast.
Old 10-04-2007, 10:28 AM   #13
Thanks Atlantic.
Yes, I do realize that I have to screw in every 16"? I thought I would have to put the screws every 12"?
Old 10-10-2007, 12:32 PM   #14
You go girl !!! Don't know if you need inspections, but in some places you need three in the field, some more. Three will do if no insp needed. And use hubby's truck, they'll load it for you at the store, he can unload it before the game and during half-time!! LOL
MudGirl is offline   Reply With Quote
Old 10-10-2007, 12:35 PM   #15
Don't forget to mark your studs on the floor/ceiling. You can eyeball it from there without worrying about missing studs.
More On This Topic
My name is Shannon Kniep on behalf of Expert Village, I'm going to show you how to cut a piece of sheetrock. We got the measurements up on our ceiling which is what we need in order to know the size of the piece that's going to fit in there. And it is... Read More »
Putting up a long sheet so I am cutting it in half so that would be 4 foot. Which would be 48. I will use an old piece of sheet rock that?s already 4 foot long make sure there is a straight edge to it. Instead of me using my level, I'm going to use this... Read More »
I like to keep a lot of my spare pieces of sheet rock just in case; just don't want to put nothing away. I can always patch up here; make them fit so that I can save my big pieces for when I need them. You?re not telling me. Some people throw their stuff... Read More »
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
We're late now. This is my homasote. I got to, like I say, fill this gap in, well, all the way across, maybe even somewhat even with this. But, once I put my sheetrock each corner should meet and I'll show you how to do that as well. Well, just measuring... Read More »
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 05:47 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 10:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 07:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 07:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 09:11 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
