Old 10-28-2011, 06:52 PM   #1
Temporary brace wall for Cathedral / Vaulted ceiling
I am cutting into an outside load bearing wall to put in framing for a new window. With a standard ceiling, I would just put a temporary bracing wall about 3 feet to the inside to support the structure, but this is the low side of a cathedral ceiling. How do I support the scissor truss from the inside?
It seems that if I cut the 2x4s studs of the support wall to match the truss and put a top plate on it, the load wouldn't transfer into the temp wall as the wall is not braced horizontally and the load would have a horizontal moment. Am I missing something obvious here? I can't find reference to a temporary support wall for a scissor truss cathedral anywhere on the web. Seems odd.
Thanks for any help.
FCdiy is offline   Reply With Quote
Old 11-03-2011, 10:55 PM   #2
Anyone have any ideas?
Old 11-04-2011, 12:12 AM   #3
2 questions- how steep is the interior pitch? And isn't the other end of the truss sufficiently tied in to the existing structure as to prevent that kind of movement? I would think all your temp wall has to do is provide bracing for vertical pressure as the other end is allready braced for lateral movement.
Ninjaframer is offline   Reply With Quote
Tags
brace, cathedral ceiling, door, vaulted ceiling, window
Vaulted ceiling crown molding with adjacent room cmcfalls2 Carpentry 4 10-13-2011 11:38 AM
Painting a wall that butts up against a popcorn ceiling... hikerguy Painting 9 08-07-2011 02:56 PM
Ceiling mounted clothes rod (one side wall mount, one side ceiling mount) DCA General Discussion 9 08-17-2009 11:13 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Vaulted ceiling molding KitSpring General Discussion 2 01-05-2006 09:19 PM
