Tempered Glass Needed Or Not? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 01:12 PM   #1
the Musigician
DangerMouse's Avatar
Tempered glass needed or not?
Hi guys!
I'm working on the new entryway which will be a 9X5 foyer with 2 doors. The side windows on the outside door are tempered glass, but the wife wants me to put side windows on each side of the inside door as well. I have some very nice decorated panes of 12" X 42" 'normal' glass I wanted to use, but is there a regulation/code on this? Height the glass needs to be from floor perhaps? I'd hate to not be able to use this glass since I've already cut and planed out the rough walnut frame I want to wrap the glass in.
Thanks!
DM
Old 04-28-2010, 01:43 PM   #2
kwikfishron's Avatar
Rewards Points: 178
In my neck of the woods any glass 18 or lower from the floor and any glass 24 from a door must be tempered. I've heard different numbers in different areas so you better call the City/County and ask.
kwikfishron is online now   Reply With Quote
Old 04-28-2010, 02:23 PM   #3
the Musigician
Do you mean within 24" of a door?
DM
Old 04-28-2010, 10:57 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
same here
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-28-2010, 11:14 PM   #5
Registered User
Rewards Points: 5,216
Here, there, should be everywhere: http://docs.google.com/viewer?a=v&q=...HPbWWaP6zwY0fg
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
DangerMouse (04-29-2010)
Old 04-29-2010, 07:34 AM   #6
Man of many hats
wrangler's Avatar
Rewards Points: 354
DM
Yes he did, and the same applies here as well.
Man of many hats
wrangler is offline   Reply With Quote
Getting impact windows ! Have two to choose from, which is best ? filo74 General DIY Discussions 13 09-01-2015 03:44 PM
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 08:37 AM
Question about GLASS bsmith6356 General DIY Discussions 2 06-26-2009 12:51 PM
stained glass ceiling help needed DangerMouse Building & Construction 6 02-23-2009 07:00 PM
When is tempered glass required? vsheetz Building & Construction 4 01-17-2009 10:53 PM
