Temperature Of An Exterior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 11:05 AM   #1
Rewards Points: 194
Temperature of an exterior wall
Need to determine the hottest time of day temperature of our west facing wood siding rear exterior wall. Will a regular outdoor thermometer do the job?
sore thumb is offline   Reply With Quote
Old 05-14-2013, 11:13 AM   #2
Rewards Points: 2,638
thermostat ? Maybe you mean thermometer. Not sure how accurate you want to be. An outdoor thermometer is going to be measuring air temperature. If there is minimal wind, the time of day that the air close to the siding is maximum, should be pretty close to the time of day the siding is maximum. For most accurate readings, find an infrared (non-contact) thermometer, or even one with a probe that can measure the surface temp of the wood.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
sore thumb (05-14-2013)
Old 05-14-2013, 01:37 PM   #3
Rewards Points: 194
Thanks for the advice. LOL, yes I meant thermometer.
Old 05-14-2013, 05:06 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
I'd say a surface thermometer would be your best way of determining the actual temperature of the walls surface. something on this line. works on your grill as well .... gotta be able to justify those new tools ya know
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Condensation on inside of windows Forrestc49 Windows and Doors 2 04-12-2013 08:03 AM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
