Temp Fix For Rotting Wood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 03:11 PM   #1
temp fix for rotting wood
Have this on the front of my house. Went to paint and noticed a section of bored that is rotted. I don't have the time or money to fix this at the current moment. Is there some way I can temporarily fix it until this summer sometime?
Michaelpro is offline   Reply With Quote
Old 04-13-2012, 03:18 PM   #2
I wouldn't expect it to take very long or cost very much to cut that piece out and replace it.
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
kwikfishron (04-14-2012)
Old 04-13-2012, 03:19 PM   #3
first thing first is to change the color
if you plan on fixing it in a few months, i would just leave it.
itsnotrequired is offline   Reply With Quote
The Following User Says Thank You to itsnotrequired For This Useful Post:
1910NE (04-15-2012)
Old 04-13-2012, 08:21 PM   #4
Just a DIY guy
I agree.
More work to temporarily fix it than it would to buy a new board and replace it. It's not holding anything up, so it's not critical.
M3 Pete is offline   Reply With Quote
Old 04-13-2012, 08:28 PM   #5
Rewards Points: 14,014
It's about a $7.00 piece of wood plus the cost of some primer and paint.
Old 04-13-2012, 08:36 PM   #6
Right so since you're up there painting now just fix it. Else you'll just have to set up again for painting again when you do fix it.
Old 04-14-2012, 01:40 AM   #7
Right you all are I should just fix it. A little afraid of ripping it out but I'm game for anything!
Old 04-14-2012, 02:30 AM   #8
It's right by a join anyway. Should be easy.
Jerk is offline   Reply With Quote
Old 04-14-2012, 11:21 AM   #9
You know I thought the same thing when I started putting it on. I planned for it to be much deeper then it is turning out to be. We have gotten several compliments from neighbors on the color.
Old 04-14-2012, 12:16 PM   #10
Structural Engineer
You can scrape away the rotted area and fill the space with Bondo wood patch (then paint it). Use a backer board to support the Bondo if the entire thickness of fascia is removed.
Or staple a piece of polyvinyl sheet to cover the area until it can be permanently repaired. If left open, water will continue to get inside and damage the soffit.
I agree with the others, that it is just as easy to repair it properly now rather than first installing a temporary repair.
House Engineer is offline   Reply With Quote
Old 04-14-2012, 06:28 PM   #11
Too Short? Cut it Again!
The Abatron wood restoration system will fix it but end up costing you more than a new piece of fascia lumber. As mentioned, this should not be a big job unless the rot extends to structure behind what we see.
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
