-   -   temp fix for rotting wood (http://www.diychatroom.com/f19/temp-fix-rotting-wood-140189/)
Michaelpro 04-13-2012 04:11 PM
2 Attachment(s)
Have this on the front of my house. Went to paint and noticed a section of bored that is rotted. I don't have the time or money to fix this at the current moment. Is there some way I can temporarily fix it until this summer sometime?
Attachment 48979
Attachment 48978
Evstarr 04-13-2012 04:18 PM
I wouldn't expect it to take very long or cost very much to cut that piece out and replace it.
itsnotrequired 04-13-2012 04:19 PM
first thing first is to change the color:jester:
if you plan on fixing it in a few months, i would just leave it.
M3 Pete 04-13-2012 09:21 PM
I agree.
More work to temporarily fix it than it would to buy a new board and replace it. It's not holding anything up, so it's not critical.
joecaption 04-13-2012 09:28 PM
It's about a $7.00 piece of wood plus the cost of some primer and paint.
Evstarr 04-13-2012 09:36 PM
Right so since you're up there painting now just fix it. Else you'll just have to set up again for painting again when you do fix it.
Michaelpro 04-14-2012 02:40 AM
Right you all are I should just fix it. A little afraid of ripping it out but I'm game for anything!
Jerk 04-14-2012 03:30 AM
It's right by a join anyway. Should be easy.
Michaelpro 04-14-2012 12:21 PM
You know I thought the same thing when I started putting it on. I planned for it to be much deeper then it is turning out to be. We have gotten several compliments from neighbors on the color.
House Engineer 04-14-2012 01:16 PM
You can scrape away the rotted area and fill the space with Bondo wood patch (then paint it). Use a backer board to support the Bondo if the entire thickness of fascia is removed.
Or staple a piece of polyvinyl sheet to cover the area until it can be permanently repaired. If left open, water will continue to get inside and damage the soffit.
I agree with the others, that it is just as easy to repair it properly now rather than first installing a temporary repair.
user1007 04-14-2012 07:28 PM
The Abatron wood restoration system will fix it but end up costing you more than a new piece of fascia lumber. As mentioned, this should not be a big job unless the rot extends to structure behind what we see.
