Telescopic Top Plate Holder - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2008, 01:08 PM   #1
Rewards Points: 1,062
Question
telescopic top plate holder
is there such a thing as telescopic top plate holder, a couple of which would allow a single framer to set one in place while exacting the position in stick framing ? i do not feel like paying somebody just to hold my top plates.
Old 06-12-2008, 02:36 PM   #2
Registered User
Termite's Avatar
Here you go. Very handy for cabinets and crown moulding too.
http://www.amazon.com/FastCap-Suppor...3295723&sr=1-2
Old 06-12-2008, 03:45 PM   #3
thanks boss ! this is exactly it !
BTW, did you see the feet that you can optionally get (recommended by Amazon) ? do you think i should get them ?
thx,
- a -
Old 06-12-2008, 04:08 PM   #4
Registered User
Termite's Avatar
Not sure. Maybe they're for slick surfaces. Might not be a bad idea.
Now this has me wanting to finally quit using pieces of 1x4 for this and spend the money on a couple of these. Uggh. I am a tool-buying addict.
Blaming you for this one.
Old 06-12-2008, 04:39 PM   #5
that looks like a load lock to me so instead of waiting for it to be shipped go to a truck stop near you and just buy a load lock not quiet as much either
clasact is offline   Reply With Quote
Old 06-12-2008, 04:45 PM   #6
Registered User
Termite's Avatar
That's a good idea. I've never seen them though.
There are a lot of places besides Amazon that sell these by the way. Check around and compare prices for sure!
Old 06-12-2008, 05:02 PM   #7
KCtermite in your area that should be no problem you got truck stops all over where you could pick em up
Old 06-12-2008, 05:03 PM   #8
Registered User
Termite's Avatar
Good idea. Truckstops have good healthy food too.
Old 06-12-2008, 05:17 PM   #9
its nice to see an inspector with a sense of humor
Old 06-13-2008, 09:37 AM   #10
yummy mummy's Avatar
Rewards Points: 1,016
I'll tell you what I did when I didn't want to ask my husband to hold the top plate for me.
I shaped a "hook" out of a coat hanger (a strong coat hanger) and nailed it in place at one end hnof the ceiling joists. Then I lifted the 2X4, hooked it on and then held it at the other end, and put a screw in to just hold it in place and voila, my top plate was up.
Easy.
I have a wild imagination.
yummy mummy is offline   Reply With Quote
Old 06-13-2008, 10:24 AM   #11
Exclamation
husbands are pretty useless these days. you go girl !
Old 06-13-2008, 04:26 PM   #12
not completely, but most of the time........
Amakarevic, I am curious, are you male or female?
Old 06-14-2008, 04:13 PM   #13
Rewards Points: 6,652
Why pay someone, when I am sure that you can find a family member to help out. That is unless you have "Burned your Bridges".
Old 06-14-2008, 04:49 PM   #14
Exclamation
SWM.
Old 06-14-2008, 11:41 PM   #15
SWM.
What does that mean? SWM?
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 07:42 PM
