TDL-How To Replace One Broken Pane? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 10:26 AM   #1
TDL-How to replace one broken pane?
I have a custom solid wood entry door with matching sidelites. All of the panes are real True Divided Lite. They are sealed double pane with tempered glass. One sidelite (thankfully interior) pane shattered. The doors/sidelites were here when we bought the house. I have checked everywhere for the manufacturer to no avail. Thankfully the glass company shipped me the stock pane but now I need help in removing the existing pane (including the metal spacer and butyl? edge that are secured with some type of adhesive. The muntins are standard Ogee sticking. I don't want to replace the entire set of sidelites. Is there a way to replace this one pane? I have pictures (and dimensions) if needed.
Jamboy is offline   Reply With Quote
Old 06-01-2010, 10:28 AM   #2
joed's Avatar
Rewards Points: 11,628
Post the pictures of both sides of the window. Usually one side is removeable and the pane comes out.
Old 06-01-2010, 10:29 AM   #3
The older I get the better I was
Old 06-01-2010, 10:31 AM   #4
I have interior picture. I will go right now and get one from outside and a new one for inside.
Old 06-01-2010, 11:16 AM   #5
Here are the pictures. Hopefully they are clear enough. I know the horizontal sticking is "removable" and most likely the male/female style. I am expecting to need to use my heat gun, breaking existing glass and buying new sticking. I really need someone to give me the steps and what I might expect (Murphy's Law). I am very apprehensive about hiring someone (even a glass company) because very few windows are TDL anymore. I feel confident in my ability to do it but need good instruction so this doesn't turn into a complete disaster.
Thanks for any help.
TDL-How to replace one broken pane?-interior-horizontal-corner-small.jpg   TDL-How to replace one broken pane?-interior-corner-small.jpg
Old 06-01-2010, 01:12 PM   #6
joed's Avatar
From the last picture is looks like you already have the bottom molding off. Remove the side and top moldings and the pane should push out.
I'm not sure what TDL is. But if the pane is stuck don't worry about breaking it. You might need a knife to cut it free from the edges. If it is really stuck, it looks the molding might come off from both sides. That could make it easier.
Old 06-01-2010, 01:54 PM   #7
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Maybe, just maybe, the process is similar enough to what is documented here
http://www.handyguyspodcast.com/32/e...7-broken-glass
Brik is offline   Reply With Quote
Old 06-01-2010, 03:06 PM   #8
Thanks for the replies. Unfortunately, this isn't a glazing points/putty type of assembly. It is solid wood moulding that holds the panes in place, inside and outside. TDL stands for True Divided Lite. Unlike almost all windows made today, TDL windows are made up of individual panes of glass divided by solid muntins. To simulate the look of individual panes, most windows today are one big pane(s) of glass that have snap on grids, grids between the two panes or some other type of Simulated True Divided Lite.
Tags
broken window , replace pane , tdl , true divided lite , window pane
Window pane replacement help dgbehrends Remodeling 17 11-19-2011 11:06 PM
Replace broken tile jergens Tiling, ceramics, marble 1 05-10-2010 07:49 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
replace broken window william farrell General DIY Discussions 3 06-07-2009 05:49 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
