Tar Seal A Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 08:55 PM   #1
Rewards Points: 370
tar seal a foundation
I'll be regrading a bit of the lawn near the house and I'm hoping to re-tar a bit of it but I don't want to buy the 5 gallon bucket they have at home depot, is there anywhere I can buy a gallon or half gallon online? I really don't need THAT much.
or do they other types that home depot sells work as well? they seem to carry a brand called "henry's"
Thank you.
MLMIB is offline   Reply With Quote
Old 03-29-2011, 09:10 PM   #2
Rewards Points: 5,336
Thank you.
Why would you want to "re-tar" the house?
Ron
Old 03-29-2011, 09:14 PM   #3
Rewards Points: 370
sorry, probably didn't explain enough. I'm re-grading the front lawn to get the water to run away from the house. With that said, I'm told taring the outside of the foundation helps to keep the water out so if I'm going to be pulling away the soil a bit to start anyway, and some of the foundation was exposed due to erosion, I figured I should re-tar it before I put all the soil against it while re-grading.
Old 03-30-2011, 04:18 AM   #4
Rewards Points: 4,656
by the time you putz around online, you'd have the work done if you grab up the gal can of henry's,,, we use it
the BIG reason to redo the area is that bldrs typically use the asphalt emulsion which has no elastomeric qualities & will crack as the house moves thereby allowing wtr to infiltrate your very fine home.
sonneborn & meadows also have great materials but not in gal cans
How to seal a leaking foundation crack from the home's exterior brokenhammer Building & Construction 5 01-02-2011 09:08 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
How to seal a shower pan liner against a concrete foundation wall? mgray87 Kitchen & Bath Remodeling 3 08-13-2009 11:08 AM
Driveway foundation seal bigboyjoel Building & Construction 5 10-07-2007 10:15 PM
