Old 11-05-2010, 11:43 AM   #1
tar paper exposed to the elements? is it fine or should it be replaced?
hi -
i'm repairing an exterior wall that currently is covered in #30 felt paper and is awaiting cedar shingles. the paper has been exposed for about one month. is it okay or should i replace it with new stuff before installing the shingles?
thanks,
mike
mklang is offline   Reply With Quote
Old 11-05-2010, 12:42 PM   #2
This is simply one man's opinion, but the felt itself is probably fine. The problem that you most likely have, or will have is that it is not holding its' shape, having been exposed to the elements for that long. If it is buckling, it seems that you could take it loose, then stretch and reattach it, otherwise, you replace it, once you are ready to install the shingles.
Old 11-05-2010, 01:05 PM   #3
thanks. other than being faded, it looks pretty good and is laying fairly flat because i already have the trim up. the only part that i don't like is the edges along the roof line where it seems to be wicking up water. i may just replace these sections and call it good.
Old 11-05-2010, 01:11 PM   #4
GC Builder/Remodeler
If the paper is intact - no tears or gaps - it is probably serviceable. Tears can be taped and gaps can be covered with another layer. If portions of the underlying sheathing remain exposed then you don't have a vapor barrier, just a partial wall covering. Also, pay particular attention to eliminating gaps around windows, doors, and other openings to the interior. Then again, depending on your location, a vapor barrier may not be necessary. Take a look at Energy.gov, and more specifically http://www.energysavers.gov/your_hom.../mytopic=11800 for some useful guidance.
tldoug is offline   Reply With Quote
Replaced motor blower now getting error 33 danny_isr HVAC 14 01-14-2010 03:35 PM
Felt Paper and the Sun. Valley problems hartkem Roofing 1 07-22-2009 04:57 PM
Finned-tube elements for hot water baseboard heat SureBert HVAC 2 12-05-2008 06:01 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 08:57 AM
