tar coat depth for crawl/basement
we use sonneborn's ' sonolastic ' but you can also use regular roofing cement,,, the protection course is VERY important - miradrain is our choice but sonneborn also has dimpleboard - just a different color,,, i would encourage you to install a proper toe drain alongside the foundation incl soil filter cloth & gravity drainage,,, failure to allow system drainabe will convert all your hard work into a drywell allowing subsequent repeat wtr infiltration
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
