Taping Uneven Butt Joints! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2009, 10:17 AM   #1
Question
Taping uneven butt joints!
If I have a drywall butt joint with one side clearly much lower than the other like in the photo, how do I begin?
Should I try to bring the low side level with some joint compound before taping so that the tape goes on flat?
Or tape right away? The tape will end up like a "stair," though with a big edge!
Lindsay8 is offline   Reply With Quote
Old 06-17-2009, 11:13 AM   #2
If the small piece of drywall is much lower remove it & shim it until it is level with the existing drywall
Old 06-17-2009, 12:08 PM   #3
Rewards Points: 5,332
If you'd rather not shim it out as Dave suggests, you can just tape over the surface disparity. Just apply the compound so the sufaces are level and press in the tape gently. You will need to spend more time compounding this if it's not level, but it can be done.
Spending the time to level it would be my choice.
Ron
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 09:09 PM
Wavy taping seams - Help (drywall taping) newbpainter Drywall & Plaster 10 05-15-2009 09:36 AM
UGH! Trim joints are opening up! javan Carpentry 5 12-16-2008 06:05 AM
caulking butt joints on siding downunder Building & Construction 7 11-13-2008 03:56 AM
Butt Joints at new drywall and existing corner round VistaV Building & Construction 1 02-03-2008 09:36 PM
