Taping OSB Sheathing Joints - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 08:31 AM   #16
MJW
We are "air sealing" all our walls here in MN. Not a good idea IMO. Good for energy, bad for mold/moisture. Which one will affect you sooner?
No horizontal gaps like mentioned in the link. Our sheathing is put on vertically and the seams on taller walls are simply blocked with 2x's.
MJW is offline   Reply With Quote
Old 01-16-2011, 09:06 AM   #17
Tom Struble's Avatar
Rewards Points: 2,002
i'm going to start drillin vent hole pores in the walls from now on
Tom Struble is offline   Reply With Quote
Old 01-16-2011, 09:20 AM   #18
KemoSabe
loneframer's Avatar
Soooo, you guys think sealing up the gaps on the sheathing is a good thing?
Isn't that moving one step closer to an exterior vapor barrier?
In my climate zone, I've been taught that the exterior wall surface needs to be several times more permeable than the interior.
Creating a non-permeable surface on both sides of the wall assembly sounds like cetain failure to me, considering the virtual impossibility of closing up all the gaps between framing and finish materials attached to the wall.
Moisture will find a way in, giving it a little help getting back out is a good thing, IMO.
If you want an airtight wall assembly, you may as well just tar and feather it, allowing it to be the albatross that it is.
loneframer is offline   Reply With Quote
Old 01-16-2011, 09:23 AM   #19
KemoSabe
loneframer's Avatar
Hmmm, perforated wall sheathing......
It's a shame that ideas already been taken by the ridgid foam guys.
Old 01-16-2011, 02:10 PM   #20
Registered User
Rewards Points: 526
In 1988, when I converted my 2 attic rooms to 3 bdrm. and a 3/4 bath, I cut slots in the OSB every 6" apart because I had installed it on new houses and knew it repelled water and of the advertised perms when it first came out here, years earlier. Don't do this if required on the corners or for a structural (shear) wall. No mold yet as I replaced some siding this year from raccoon damage, though the 15# felt paper was thin and brittle. (use 30#, especially today.......) Tom, Dupont Tyvek is one of the spray-on, air barrier but moisture permeable; http://docs.google.com/viewer?a=v&q=cache:uawmJu69hb0J:www2.dupont.com/Tyvek_Weatherization/en_US/assets/downloads/pdfs/072619%2520-%2520Dupont%2520Tyvek%2520Fluid-Applied%2520Weather%2520Barrier%25208%2520Apr10%25 20FINAL%2520(2).doc+test+of+air+leakage+at+sheathi ng+joints&hl=en&gl=us&pid=bl&srcid=ADGEESjlBfOXaN6 7ZGT7b6MnI1csjEoovZyTBxmqUVawL27OnbWrZRsBP8HGxSDMv IJKuCT9EwO0QoZEZ3QAwQTlqpvaoyxN6UdiJc6uokDDCEml7-utVElaQL-3HuflzCpNvS8Icw3i&sig=AHIEtbR2MyFSlEMDVUtt8eiQhngF LZ5U6Q
Gary
Old 01-16-2011, 03:35 PM   #21
Originally Posted by loneframer View Post
Sooo, you guys think sealing up the gaps on the sheathing is a good thing?
Creating a non-permeable surface on both sides of the wall assembly sounds like certain failure to me, considering the virtual impossibility of closing up all the gaps between framing and finish materials attached to the wall.
i don't think taping the osb seams is a good idea,or even effective over the long term,and combining that with a foam wrb,well...i for one have my doubts
i know Gary keeps telling me how much less permeable osb is compared to ply,it's just that in my experience ive never personally seen a big difference [from a moisture management point] between the 2
just like i never saw a difference between plastic or felt wrbs,i read the science but i don't see the difference in my ''real'' world
Old 01-16-2011, 04:31 PM   #22
KemoSabe
loneframer's Avatar
Well Tom, real world conditions are what I base my opinions on as well.
I believe my own two eyes before I believe what I read. However, when I read something that reinforces what I have seen with my own eyes, it carries more weight.
Old 01-16-2011, 08:17 PM   #23
i wasn't tryin to be persnickety
http://dictionary.reference.com/browse/persnickety
i know you have seen tyvek become brittle,so have ibut only the early version
Old 01-16-2011, 09:02 PM   #24
KemoSabe
loneframer's Avatar
I wasn't sniping at you Tom. I still bow to the vinyl king.
I was speaking in broader terms than that, but since you brought it up, yes I prefer asphalt saturated felt for a WRB, in almost every scenario.
All together now..."Variable Permeability"
Old 01-16-2011, 10:07 PM   #25
i know i know i know i know........your the best
Old 01-17-2011, 06:48 AM   #26
OSB has variable permeability as well. Once it turns to mush it is totally permeable.
jmiller is offline   Reply With Quote
Old 01-17-2011, 06:51 AM   #27
Old 01-17-2011, 10:27 AM   #28
Registered User
Rewards Points: 526
Figures 27, 46, 57, 77, etc.,........ http://www.google.com/url?sa=t&sourc...DCcvwQ&cad=rja
Gary
Old 01-17-2011, 04:49 PM   #29
KemoSabe
loneframer's Avatar
Oh, I see how it's gonna be around here.
The Following User Says Thank You to loneframer For This Useful Post:
Tom Struble (01-17-2011)
Old 01-17-2011, 05:33 PM   #30
Yup, Tom and I try to act like we know what we're talking about
The Following User Says Thank You to jmiller For This Useful Post:
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 09:09 PM
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 08:57 AM
Support for garage foof sheathing. Jim F Building & Construction 3 10-23-2010 01:46 AM
taping hardibacker joints. cure time? tarheelblue Flooring 2 01-23-2010 12:18 PM
Taping uneven butt joints! Lindsay8 Building & Construction 2 06-17-2009 12:08 PM
