Taping An Inside Corner? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2008, 08:52 AM   #1
Taping an inside corner?
I was taping an inside corner, and by mistake when I was passing the knife to get the mud out of the tape, the knife cut into the tape right where the tape folds. Can I cover this up with the mud on the next pass, or do I have to put a piece of tape to cover this? I will assume the mud will cover this.
Thanks, P.S. I think the knife might be a little sharp from some much taping.
helpless handyman is offline   Reply With Quote
Old 09-25-2008, 09:45 AM   #2
Registered User
Termite's Avatar
If the cut occurred right at the corner, I'd say that it would be a good idea to overlay it with another piece of tape. If it is only 1/2" long I wouldn't sweat it. If it is longer than an inch or two I'd fix it with tape. Be sure to bed the replacement tape in some mud and don't just go over the top of it.
Yes, mud will conceal, but you've got a good potential for a small crack there.
Old 09-25-2008, 03:34 PM   #3
Thanks KCtermite, I will definately add another piece of tape over it to be on the safe side. Don't want it haunting me in a few years, I haven't given it the second coat, so this is the time to do it.
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
First coat on inside corner, need advise.. helpless handyman Building & Construction 6 09-24-2008 01:22 PM
Taping inside corners....one side at a time? yummy mummy Building & Construction 10 07-23-2008 03:23 PM
Building a deck on an inside corner ternstes Carpentry 3 06-16-2008 09:45 PM
Baseboard - inside corner Potomac101 Flooring 11 02-16-2008 11:44 AM
