Tape Drywall To Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 11:25 AM   #1
tape drywall to plywood
New to the site--looks great. I'm putting in a "side mount pullout rack" Making an opening in the wall( which is drywalled) I want to put good 1 side plywood on the inside of the "cupboard" Can the corner where the drywall and plywood meet be taped as if it were drywall to drywall? Thanks for any help!!
dguy is offline   Reply With Quote
Old 04-08-2010, 03:16 PM   #2
Pro
Nostco's Avatar
You can do it, but the joint will probably crack.
Drywall butting up to wood usually requires a trim piece (cove molding or something similar) to hide the gap.
Wood shrinks, wood expands...mud doesn't like that
Nostco is offline   Reply With Quote
Old 04-08-2010, 07:15 PM   #3
Drywall contractor
Rewards Points: 1,070
Yeah, the movement of sliding the rack in and out over time will likely crack the joint. If you decide to try it, I'd recommend using "brown bag" DuraBond for the tape and bed coats....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Fiberglass drywall tape on ceiling lgallo Drywall & Plaster 1 03-21-2010 10:05 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Repairing drywall tape bcouch Drywall & Plaster 2 09-08-2009 03:19 PM
tape and float plywood grandpa General DIY Discussions 4 01-13-2009 02:11 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
