Tapcon Not Holding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-14-2007, 08:46 PM   #1
Tapcon not holding?
Hi all,
I'm trying to put up a short section of fence along the drive way. I have a fence post holder (made out of plastic from the home hardware store), which takes four tapcon screws (? they are screws for cement at least, and have a hex top). I drilled a hole with a 3/16th bit (the screws say they are 3/8ths mind you...) about 4-1/2 inches (screws are 2-1/2"ish). When putting the screws in the threads seem to strip away to nothing - is my hole just too small? Once fully inserted, the screws come out fairly easily leveraging the fence post.
What's the best method of proceeding - should I just get more screws and a 3/8 bit and use the same holes? Or....any other thoughts as to why the screws are stripping?
TIA...
p
phantoz is offline   Reply With Quote
Old 10-15-2007, 05:36 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Not sure if tapcons are going to hold that fence post properly for you. Maybe look into wedge anchors.
As stated, I am not sure if the tapcons are the right fastener for this job. However, you could try some longer tapcons and concrete epoxy. It also sounds like you are drilling the holes slightly larger than they should be drilled.
- Build Well -
Old 10-15-2007, 11:55 AM   #3
I agree ... tapcon may not be strong enough for this application... I would use those expansion anchors also for this type of application... depends on how strong you need, you may even need a few thick ones driven deeper...etc... good luck...
KUIPORNG is offline   Reply With Quote
Old 10-19-2007, 12:16 AM   #4
Much thanks! Picked up some wedge bolts & epoxy and everything has gone off nicely!
Chris
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Sealing the roof jack holding refrigerant lines. pines HVAC 1 08-16-2007 05:58 PM
These Tapcon Screws Are A Bear Stingray Remodeling 14 04-23-2007 07:40 PM
Hot Water Holding Tanks - Moved to Plumbing Forum Boatnuts Plumbing 1 04-19-2007 06:44 AM
Holding ceiling light fixrure during installation jdemaray Electrical 2 01-15-2007 08:45 AM
