Tapcon Nightmare - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 06:55 AM   #1
Tapcon Nightmare
Hi,
I am finishing my basement and had a few friends over to help out with attaching the plywood to the basement floor. In between the basement floor and the plywood was one inch of XPS foam. The next day, I had this feeling that they drilled through the floor. I checked and my worse nightmare came true, they did. What can I do to fix this? Epoxy Caulk into each hole?
Thanks,
Dan
GeronimoDF is offline   Reply With Quote
Old 04-23-2011, 07:00 AM   #2
i don't understand the problem. your friends did the right thing as the plywood needs to be fastened.
just put down a layer of 30lb. felt paper on top of the plywood, followed by your finished flooring and you're good to go.
wombosi is offline   Reply With Quote
Old 04-23-2011, 07:08 AM   #3
They drilled through the concrete floor.......right to the dirt
Old 04-23-2011, 07:12 AM   #4
But they put the tapcons in right?
The holes they drilled were to pre-drill the tapcons?
If going through plywood, 1" of foam, and the slab, your slab must be extremely thin.
Still, unless I'm missing something, if they've sent the tapcons home through those holes, who cares? It's as it should be.
Old 04-23-2011, 07:19 AM   #5
I am worried that water is going to come through the holes they drilled......Hydrostatic pressure......
Old 04-23-2011, 07:24 AM   #6
It all depends on where you are, what the water table is, what your soil is like, how your foundation was built, etc..
For example, I'm in the northeast in a 100 year old house. I have a big hole take out of my slab where the old coal furnace used to sit. There is just dirt there.
Never a drop of moister. My basement never gets wet.
This is unusual, though. Obviously there is no waterproofing membrane, no site drainage, etc... Just lucky.
Did your basement take in water before you put down the foam and plywood?
How old is your foundation? Does it have a drainage system built in around the outside?
Unless you previously took in water, I wouldn't worry about it.
Otherwise, I would build an accessible chase wherever the lowest point in the floor is, and install a sump pump.
Old 04-23-2011, 07:31 AM   #7
Rewards Points: 5,336
Originally Posted by GeronimoDF View Post
Hi,
Thanks,
Dan
What size screws did you use? In a normal thickness slab you would need a bit 5-6" long to go through it.
Did you have an issue with water before?
How old is the house?
Ron
Old 04-23-2011, 07:33 AM   #8
I have never had water in my basement and also have a big hold in the corner of my basement and it has always been dry as a bone. All the run off from the roof is directed into the street. The front of the house has a porch, so no chance of water coming from the front, the side is the garage, so no chance and the back is graded away from the house. I also live in the Northeast, Long Island to be exact. What do you think now?
Old 04-23-2011, 07:35 AM   #9
live your life, sir, and don't worry about the holes.
it will never be an issue.
put down your new floor and have fun.
just remember the underlayment. i would use 30lb. felt.
Old 04-23-2011, 07:41 AM   #10
Ron
Old 04-23-2011, 09:13 AM   #11
Probably should tear down the house, dig a new foundation, rebuild the house, find new friends....
karteberry is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Mount LCD in Brick with Tapcon Screws shacky meatwad Home Theater 6 12-11-2009 06:27 PM
Tapcon quality? Ultrarunner2017 Tools 18 06-18-2009 07:55 AM
Drainage/Erosion NIGHTMARE!! Please help! Jamer2168 Landscaping & Lawn Care 27 04-09-2009 11:21 AM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 03:57 PM
