Tapcon Or Masonry Nail? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 03:49 PM   #1
tapcon or masonry nail?
Hey guys I'm really not sure which anchor type to use. Im thinkin about furring out my basement concrete block wall to attach 1/2" drywall. I feel more comfortable with tapcon screw method over masonry nails. DOes it matter for tapcon screw if I drill into mortar versus main block?
Aloha1 is offline   Reply With Quote
Old 09-19-2011, 06:46 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Use screws, the nails usually don't hold well in block walls and don't screw into the mortar joint, it usually won't hold either.
You can use deck screws and a strand of electrical wire #12 romex cheaper than the tapcons. Drill hole put strip of wire in the hole and screw in the screw, it will hold and you can sink it head of the screw most times.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-19-2011, 09:28 PM   #3
Jiju...Thx for tip.
Old 09-19-2011, 10:02 PM   #4
Concrete & Masonry
Rewards Points: 468
Stick with the Tapcons, or use the nail (or screw) and wire shortcut that juju posted.
jomama45 is online now   Reply With Quote
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Framing nail gun is blowing holes in my fence TheMac13 Building & Construction 4 06-28-2010 06:31 PM
Low Profile Masonry Receptacle box? Lovegasoline Electrical 0 12-02-2009 02:01 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 09:46 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 09:10 PM
