T&G Pine & Vapour Barrier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 07:28 PM   #1
Hi Guys, great site! I just purchased 5/8" 1 x 6 x 8' Knotty pine which I will be bringing to my cabin this weekend. I will be installing it in the next couple of weeks once the wood is acclimitized. Basic info follow
Installed Vertical
Studs on 16"
6.0mil Vapour Barrier
1 x 4 Strapping spaced roughly 15" - 20" apart
Live in Canada and get -40 in the winter but keep it heated
I will be using a 18g air nailer to install the boards.
I have 5/8" (Pine) + 3/4" (Strap) = 1 3/8" total
I will be using a 1.5" - 2" nail. Doing so will be putting a small hole into my vapour barrier, will this cause a problem? If so, will a 1 1/4" nail be strong enough to hold the wood? I was also thinking of using glue when installing to help keep the wood secure. Anybody input would be great!!!
Thanks in advance!
Jonboy82 is offline   Reply With Quote
Old 04-21-2011, 07:59 PM   #2
Anybody???
Old 04-22-2011, 11:24 AM   #3
mem
Rewards Points: 156
The 1-1/2" nail would be fine presuming you are blind nailing thru the tongue at a 45 angle. Two inch are a tad too long tho. I wouldn't glue it as it's going to want to move with humidity changes.
mem is offline   Reply With Quote
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 08:08 PM
Vapour barrier over potlights? GBunny Electrical 2 03-25-2011 11:03 PM
Old paper-backed insulation = Vapour Barrier? billyh Building & Construction 3 03-15-2011 08:38 PM
Densshield and Vapour Barrier rayf01 Building & Construction 6 01-01-2010 12:55 PM
