T&G Paneling On Stucco Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 02:02 PM   #1
Rewards Points: 20
T&G paneling on Stucco ceiling
Hello,
I am thinking about installing tounge and groove pine paneling on my ceilings which are stucco. I would like to know how to go about this with out removing the stucco. I feel the stucco will not allow the boards to sit flush. I was thinking that I could install particle board (or something) on the ceilng first. Then nail the boards over that. Let me know if anyone has any advice or experience with this.
Thanks,
Anthony
atonkennedy is offline   Reply With Quote
Old 10-26-2011, 02:45 PM   #2
robertcdf's Avatar
I would frame it down with 2x material first, it will give you an even surface
robertcdf is offline   Reply With Quote
The Following User Says Thank You to robertcdf For This Useful Post:
atonkennedy (10-27-2011)
Old 10-26-2011, 03:42 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
By 'stucco', do you really mean popcorn texture? Or is it the typical trowled texture?
I would avoid attaching particle board...you would be adding a lot of weight....and unless your really careful about how you attach it....by the time you add the T&G....I would be concerned about fastners holding it.
I would attach directly to the ceiling. I'm assuming your going to use 3/4" thick wood....it has enough stiffness that it will smooth out any bumps. To be sure...take a drywall sanding block and run it over the entire ceiling to remove any high spots..
Also....make sure you use long enough nails....figure the T&G is 3/4"....your ceiling drywall is at least 5/8" + texture (assume 3/4" total). You want a min of 1" penatration into the ceiling joist....so your looking at a 2 1/2" finishing nail.
Old 10-26-2011, 03:43 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is it real stucco or does it just look like stucco?
I'm sure what "tongue and groove pine panelling" is. What is it?
Old 10-26-2011, 09:20 PM   #5
Rewards Points: 20
Thank you for the information.
It is the trowled texture, not popcorn. I thought it may be heavy but I am trying to avoiding sanding because it will be a huge mess. If the 3/4" thickness will work better than I will use that.
Old 10-27-2011, 08:07 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
WTF are you guys doing?
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 07:23 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
How do I remove stucco from a ceiling painted with oil paint labnotes Painting 4 01-09-2007 11:26 AM
