Old 07-04-2012, 08:43 AM   #1
Smile
Switch to Trex Elevations
I have a 20x14 PT deck. I'm switching to Trex. I decided after buying the decking, I should also do the Trex Elevations so the decking doesn't get wavey due to the imperfect wooden joists. I have 4 posts since my current 2x10's span the 14 ft. The deck is only 6" off the ground if that so a drop beam is not possible. The header beam is currently two 2x10's that the joists run into (no cantilever). On to my questions.
If I go to Elevations and start over...they are 8" joists. So I need an 8" ledger. Should I put the new elevations ledger ON the existing ledger or replace it all together. Also, since the existing ledger is 10", the new ledger is 2" shorter so my existing holes won't line up right. Drill new holes?
Back to the header beam, same thing. I assume I should replace it with the Elevations beam? Should I replace it with 2 beams or would one suffice? If two beams, should I bolt them together like I did the wood? Since these won't warp maybe I don't need to do that or just bolt it in a few places so it doesn't slip?
I'm also picture framing the deck with surface mount posts as railing (I think). Surface mount posts need support underneath so I figured I'd add a steel block (horizontally though) flush with the joists for the post to grab onto. Anything wrong with that logic?
I've seen lots of great answers on this site, great site. Appreciate any advice on the above. Thanks.
jensor is offline   Reply With Quote
Old 07-04-2012, 09:19 AM   #2
http://www.nadra.org/consumers/decks_glossary.html
I find your post a little confusing, may be just some of the terms used.
There are no "headers" in deck constrution. Not sure how a "steel block" comes into play when adding the railings. A simple drawing or picture may clear things up.
Just how far off are the floor joist that you think you need to go to all that extra work?
Any composite decking I've worked with states in the install directions to not install any closer then 12" from the ground. Reason being is for air flow to keep the decking from molding up.
Most also say to have the joist no further apart then 16", 12" of your installing on an angle, how far apart are your joist?
Old 07-04-2012, 10:39 AM   #3
Sorry about that. The header - I mean the beam that is opposite the ledger that the other end of the joists hang on to. The ledger and "the beam" are level, but over time the wood joists bow. So now they are off 2 inches from the highest board to the lowest. I'm afraid even if I replace the wood joists, they will do that again over time creating waves in the trex decking. Attached is a pic of half my deck. Totally open to suggestions.
Last edited by jensor; 07-04-2012 at 10:43 AM. Reason: Forgot to answer a question - 16 O.C.
Old 07-04-2012, 10:57 AM   #4
So your joists have a 2" dip in them?
Exactly how far do they span?
What is there size?
framer52 is offline   Reply With Quote
Old 07-04-2012, 11:02 AM   #5
The joists are 2x10's spanning 13 feet (unlucky I know) - this I thought met the requirements. Yes, some have bowed 1.5 to 2 inches. So if I flip them, then there is a hump. And by what I can tell on other threads, it looks like 1/2 inch here and there will make the trex decking look wavey....that's why I was thinking about steal - which is 8" so I'd have 2 more inches under the deck for venting.
Old 07-04-2012, 11:38 AM   #6
steel would be fine.
I don't care for man made decking material.
Old 07-04-2012, 11:42 AM   #7
1.5 to 2" is a lot, I have not seen that before.
Unless they are cracked.
mae-ling is offline   Reply With Quote
Old 07-04-2012, 11:45 AM   #8
Not to be a pain, I had a few question in the original thread. If I go to Elevations and start over...they are 8" joists. So I need an 8" ledger. Should I put the new elevations ledger ON the existing ledger or replace it all together.
I also asssume I should replace the beam with the Elevations beam? Should I replace it with 2 beams or would one suffice? If two beams, should I bolt them together like I did the wood? Since these won't warp maybe I don't need to do that or just bolt it in a few places so it doesn't slip?
Old 07-04-2012, 11:49 AM   #9
If it were mine, I would rip it out and redo the whole thing.
Old 07-04-2012, 12:48 PM   #10
If you are going that far I agree go all the way and use the whole system.
Old 07-04-2012, 06:50 PM   #11
robertcdf's Avatar
Wow... a lot of people don't know what the elevations line is, for those that don't know what elevations is, it is a Cold rolled galvanized steel system with a powdercoat finish, it's identical to the system I use except I don't powdercoat it (they actually use 1 5/8" width joists, I like 2" better). As someone who has been building steel frame decks for 3 years I can tell you that as long as your loading is typical (15# SF DL, 40# SF LL) then the 8" joist will span your 13' without problem, you can use the "Single" beam that they have and put your support posts 8' apart and you'll be golden. I would remove the existing ledger and install the steel ledger, seal up the old holes and install new bolts and holes (try to avoid laying out bolts where they are close to an old one)
I would opt for posts that come through the framing instead of top mounting, if you do continue to top mount then use a block of lumber (maybe a redwood 4x8) that is attached to the framing.
One thing to keep in mind is steel deflection is different than wood deflection, you'll "feel more bounce" in your deck with steel joists but it's perfectly normal.
Your local building department is likely going to require and engineers stamp for you to go forward with this project since steel as deck framing is considered "non conventional"
robertcdf is offline   Reply With Quote
Old 07-04-2012, 07:22 PM   #12
Moderator
kwikfishron's Avatar
There shouldn't be any "bounce" in a deck or any floor for that matter, regardless of material used.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
mae-ling (07-04-2012)
Old 07-04-2012, 07:57 PM   #13
robertcdf's Avatar
Clearly you don't have a clue what you're talking about. Look up deflection. There are allowable loads and if you know how to make a floor deflect you can make ANY floor deflect.
I've seen a commercial floor at a concert move 2" - 2.5" because of the jumping fans, it was in a commercial building with a steel floor system and concrete floor. At no time was I worried about safety because I understood deflection.
Old 07-04-2012, 08:05 PM   #14
robertcdf's Avatar
Here is a good little course so you can begin to understand deflection. http://www.ronblank.com/courses/ufp06a/ufp06a.pdf
If you don't like the minimum code for deflection (maximum movement) then specify something more to your liking, however that raises the costs and material usage to compensate.
Old 07-04-2012, 08:22 PM   #15
Moderator
I know about and understand deflection robbie, just because it may always exist doesn’t mean you can or should be able to feel it.
If you want to include “ a bouncy deck is perfectly normal” in your pitch that’s up to you, it won’t happen in my world though because there will be no bounce to explain away.
-NEW MEMBERS-
oh'mike (07-05-2012)
Tags
building deck, deck, elevations, trex
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
