Swing Installation Inside The House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2014, 09:49 PM   #1
Swing installation inside the house
Hi
We are building a new house & we want to install a swing inside the house. The builder wants to install the hardware to hang the swing from with a lag bolt rather than a traditional nut and bolt. I have attached the hardware, similar swing & the provisions made on the ceiling. Could you tell me if a lag bolt (1/2 inch lag bolt which is 3 inches long) would suffice or should we insist on something else.
Swing installation inside the house-appas-camera-slim-137-1-.jpg   Swing installation inside the house-nik_8715.jpg
murlishaan is offline   Reply With Quote
Old 07-01-2014, 10:14 PM   #2
DIY staff
Rewards Points: 7,174
Are you speaking of a lag screw?
If the timber is strong enough--two lag screws would hold---
A through bolt and nut might be extremely difficult to attach unless there is attic space above------
Old 07-01-2014, 10:25 PM   #3
Yes, it is a lag screw only. What length & width would you suggest ? I did attache the pic of the timber as well. Would that do ? I was insisting on a thru' bolt and nut but my builder vouches on the lag screw. Would it withstand the weight & how much do you think it can withstand ?
Thanks for your suggestion
Old 07-02-2014, 06:03 AM   #4
DIY staff
3 inch x3/8 inch --even smaller will hold well---to large can split the bottom of the joist---
An engineer will be needed to quote the sheer strength---I just don't remember that sort of thing----As a millwright,I have hung some mighty heavy machinery over the years---my biggest concern is the drywall--the wiggling of the block may crush the soft material--leaving the swing block loose---consider adding a wood or steel plate below the drywall.
Old 07-02-2014, 09:41 AM   #5
Rewards Points: 2,078
I'm not fully understanding the ceiling prep picture but that point is moot in my mind and here is why.
I would not use lag screws screwed into a single ceiling joist. The tinsel strength of the screw isn't the problem but the screw is forming wooden threads, will weaken the joist and that is the problem.
If mine I would sister a 3 ft. long 2x4 on each side of the ceiling joist, centered on attachment locations using glue and screws and those would be bridged to two adjoining joist in each direction. One of the sistering 2x4s would have two 1/4" grooves cut to accept 1/4" bolts. If you question the bolts that size research the tinsel strength of 1/4" fine thread bolts. A 1/4" thick steel plate, with matching holes, would be in the attic on top of the sister lumber on the bolt side and covering the ceiling joist. If the bolts don't fit the hardware holes put a bushing in the holes.
This setup shouldn't be taken lightly.
SeniorSitizen is offline   Reply With Quote
Old 07-02-2014, 02:42 PM   #6
Rewards Points: 992
I bought some in Lowes yesterday. I told the cashier they were lag screws, but he had trouble finding them in his guide because they are called lag bolts there. Go figure.
Toller is offline   Reply With Quote
Old 07-02-2014, 05:42 PM   #7
Rewards Points: 744
what the.... (to each their own, I guess)...
You chain is likely going to break long before the lag bolts pull out.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
oh'mike (07-02-2014)
Ice/frost inside house, corner of the room doogie88 Building & Construction 7 01-26-2013 07:41 AM
Leviton timer installation - ok with whole house fan? feign3 Electrical 8 03-16-2010 05:16 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
How cool should it be inside the house? beer_geek HVAC 8 05-13-2007 01:42 PM
Sealing exterior wall from inside the house? BigJimmy Building & Construction 6 03-20-2007 09:16 PM
