Sweating On The Windows And Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 10:38 AM   #1
Sweating on the windows and door
only my back yard door and the window facing the backyard sweats which is in the main living room the bedroom windows does not sweat. I have a double glass door, I just turned off my humidifier as someone told me to try that, it will be one week tomorrow but till today it is still seating, also closed the water flow to the humidifier, please suggest
rdsouza99 is offline   Reply With Quote
Old 08-20-2010, 10:50 AM   #2
Rewards Points: 558
It could be that the seal is broken between the double glass causing condensation.
epson is offline   Reply With Quote
Old 08-20-2010, 10:56 AM   #3
fabrk8r
fabrk8r's Avatar
Is it sweating on the interior side of the glass?
Are you running A/C?
What is the temperature inside your home when this occurs?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-20-2010, 02:52 PM   #4
And get an indoor relative humidity reading and what's the weather been like outside?
Kind of wierd why it would be sweating on the inside of the glass. Would make more sense if were between the panes or on the outside this time of year.
dhag is offline   Reply With Quote
Replacing windows with sliding patio door, should I match widths? TomServo Building & Construction 5 09-21-2009 07:22 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Adding large windows and a door to existing wall cpused Remodeling 7 02-23-2008 10:07 AM
new commercial door in place of windows crecore Building & Construction 3 11-21-2007 05:29 PM
