Sweating Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 11:33 PM   #1
ewf
sweating walls
how to remedy sweating walls
ewf is offline   Reply With Quote
Old 03-31-2011, 12:44 AM   #2
sweating walls????
beerdog is offline   Reply With Quote
Old 03-31-2011, 01:13 AM   #3
Learning by Doing
Leah Frances's Avatar
Yes, walls sweat. Minimizing temperature and humidity differences can help, but every spring I am faced with some amount of this. Warm wet spring air will condense on the cool walls.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-31-2011, 01:15 AM   #4
Registered User
Rewards Points: 4,936
Welcome to the forum! Where are the walls, what is the wall finish material, etc. Keep them warmer.
Gary
Old 03-31-2011, 11:23 AM   #5
Learning by Doing
I also have a pretty unique situation. 16 inch thick brick walls in my 200 year old farm house have low thermal inertia. Once the weather warms up outside it takes them 4-6 weeks to catch up. Which is nice for being able to hold off on turning on the A/C.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 10:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
