Sweating Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 12:49 PM   #1
Sweating door
My wife and I have bought a house in Ohio and the door to the backyard is a wood frame french patio door. When it is cold outside the door that does not open sweats alot. The door that does open does not sweat at all. I do not feel any air coming from the frame of either door. What can I do to fix this problem.
Bronx is offline   Reply With Quote
Old 02-23-2009, 09:35 PM   #2
Remodeling Contractor
Is it the door frame that is sweating or the glass in the door? If it's the glass, is it on the inside surface or between the panes?
Do you have forced air heat with a floor register in front of the set of doors? Is it directing air towards one but not the other?
Constructive1 is offline   Reply With Quote
Old 02-24-2009, 06:20 AM   #3
Heres the info
Its the frame and the wood between the windows. There is a register in front of the center of the two doors. I belive that the air is blown toward the room and away from the doors. It is a forced air furnace.
Installing steel entry door NoExperience Carpentry 2 10-23-2008 11:23 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 05:55 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
