Swap Existing Bathroom Exhaust For Newer, Quieter Fan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 01:44 PM   #1
Question
Swap existing bathroom exhaust for newer, quieter fan
I have an existing exhaust fan in the bathroom that has become noisy with wear and tear. The opening measures approximately 12.4 inches by 12.4 inches. (see pic)
I would like to swap it out for a newer fan that is quieter. (http://www.homedepot.ca/product/quie...-90-cfm/946043), but measures 12.4 inches x 15.3 inches.
Would this involve cutting the drywall to expand the hole? If so, what tools and other equipment will I need? Is this manageable for a very novice DIYer?
python-django is offline   Reply With Quote
Old 02-08-2013, 01:58 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by python-django View Post
I would like to swap it out for a newer fan that is quieter...
Do you have access to the fan from above?
If so... then the job is at the lower "annoying" level.
It'll still be a mess and take a while... but not overly complicated.
Old 02-08-2013, 02:03 PM   #3
I do not have access from above, but this video seems to make it seem deceptively easy.
Old 02-08-2013, 02:33 PM   #4
Rewards Points: 44
It's going to be hard to do with out access from above. You need to figure out how to get the old fan out. The model fan you selected gets mounted to the joists either directly or with hangers.
I recently installed 2 Nutones in my house. It wasn't too bad but I had access from above.
This will take you to the product page with the installation manual.
http://www.nutone.ca/product-detail.asp?ProductID=10903
djlandkpl is offline   Reply With Quote
Old 02-08-2013, 02:38 PM   #5
Rewards Points: 14,312
Or you can just replace the motor, which can all be done from blow.
Old 02-08-2013, 02:51 PM   #6
Civil Engineer
Rewards Points: 4,952
You also need to reinstall the wiring, and based on my recent job doing a similar replacement of a bathroom fan, I don't see how I could have done the wiring without access from my attic. There is usually a small junction box on the fan, this is where you connect the wiring. In my case, the connection box was on the opposite side of the fan from where the old box was, which made the job slightly more difficult.
Old 02-08-2013, 04:18 PM   #7
Most have a plug in motor, remove the 4, screws and drop the motor down to see if there a plug.
Could be as simple as the fans dirty.
Tags
bathroom , exhaust fan , fan
multiple bathroom exhaust fans into one vent?? JulesB HVAC 9 06-05-2011 07:15 AM
Wrong roof vent for bathroom exhaust? vanishingson Roofing/Siding 18 04-04-2011 06:25 AM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
bathroom exhaust maintenance HVAC 14 12-10-2007 06:27 AM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
