-   -   Swap existing bathroom exhaust for newer, quieter fan (http://www.diychatroom.com/f19/swap-existing-bathroom-exhaust-newer-quieter-fan-171388/)
python-django 02-08-2013 01:44 PM
2 Attachment(s)
I have an existing exhaust fan in the bathroom that has become noisy with wear and tear. The opening measures approximately 12.4 inches by 12.4 inches. (see pic)
I would like to swap it out for a newer fan that is quieter. (http://www.homedepot.ca/product/quie...-90-cfm/946043), but measures 12.4 inches x 15.3 inches.
Would this involve cutting the drywall to expand the hole? If so, what tools and other equipment will I need? Is this manageable for a very novice DIYer?
TarheelTerp 02-08-2013 01:58 PM
Originally Posted by python-django (Post 1112459)
I would like to swap it out for a newer fan that is quieter...
Do you have access to the fan from above?
If so... then the job is at the lower "annoying" level.
It'll still be a mess and take a while... but not overly complicated.
python-django 02-08-2013 02:03 PM
I do not have access from above, but this video seems to make it seem deceptively easy.
djlandkpl 02-08-2013 02:33 PM
It's going to be hard to do with out access from above. You need to figure out how to get the old fan out. The model fan you selected gets mounted to the joists either directly or with hangers.
I recently installed 2 Nutones in my house. It wasn't too bad but I had access from above.
This will take you to the product page with the installation manual.
http://www.nutone.ca/product-detail.asp?ProductID=10903
joecaption 02-08-2013 02:38 PM
Or you can just replace the motor, which can all be done from blow.
Daniel Holzman 02-08-2013 02:51 PM
You also need to reinstall the wiring, and based on my recent job doing a similar replacement of a bathroom fan, I don't see how I could have done the wiring without access from my attic. There is usually a small junction box on the fan, this is where you connect the wiring. In my case, the connection box was on the opposite side of the fan from where the old box was, which made the job slightly more difficult.
joecaption 02-08-2013 04:18 PM
Most have a plug in motor, remove the 4, screws and drop the motor down to see if there a plug.
Could be as simple as the fans dirty.
