Suspended Ceiling Min Height? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2008, 03:17 PM   #1
Hello.
I'm going back and for between drywall and suspended ceiling because of my basement heights. What is the absolute min. distance from U/S I Joists to suspended ceiling. Do I really need 3" or can I get away with less?
Matt
mfleming is offline   Reply With Quote
Old 10-15-2008, 03:29 PM   #2
Drywall contractor
Rewards Points: 1,070
Your main and cross tees are 1-1/2" tall and you have to have room to twist the tie wires. I don't see getting by with any less........ If you are using any "lay in" lights, you'll need a minimum of 4". And you need room to get the tile in.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-15-2008, 04:43 PM   #3
3-4" is what I thought. I guess I'm doing drywall and hopefully I don't get too much cracking when my floor moves.
thanks
Old 10-15-2008, 06:11 PM   #4
I used flexible fiberglass 2' x 4' ceiling tiles for my suspended ceiling because I wanted the maximum height for my basement ceiling. The distance from bottom of the 2"x10" joists to the top of the metal track is 1.75". I had no problem installing recessed lighting and placed the tie wires at strategic spots that reduced interference. I like drywall but I hate installing them horizontally and removable tiles make repairs and running new electric/speaker/alarm wires easier.
aggreX is offline   Reply With Quote
Old 10-15-2008, 07:34 PM   #5
Registered User
Termite's Avatar
Just for reference, the International Residential Code requires a minumum 7'-0" ceiling height.
Old 10-16-2008, 12:25 AM   #6
I'll have 7'-1" in most places. Some places I'll have boxed in areas for ductwork. My house is only a year old and they built it like crap. Next time I'm designing and building my own.
Old 10-17-2008, 08:42 AM   #7
Drywall contractor
I install drywall on I joists a lot. No more problems than regular "stick" framing.......Sometimes they are over 16" centers, if so you may want to use 5/8" rock to keep from sagging.
Height of a ceiling fan with a trey ceiling? Bacardi 151 Electrical 7 09-08-2010 10:55 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Code for basement ceiling height RDS Building & Construction 3 04-22-2008 10:46 AM
Ceiling fan suspended ceiling bdalekid Electrical 15 03-17-2007 11:03 AM
raising ceiling height during remodel marks Building & Construction 1 10-04-2006 01:58 PM
