Survey Results - Cavity Wall Insulation - Health Concerns - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2007, 02:03 PM   #1
Exclamation
Hi,
I've just received my full building survey report for a property I am interested in purchasing. However, it mentions the existence of cavity wall insulation but not what TYPE (e.g. foam, etc.)
I have been told (by a friend) that if it is foam based, then to avoid the property as there are health concerns associated with such insulations (and cannot be removed as it is stuck to wall like expanding foam). These foam based insulations are now banned (so I believe).
I am no expert in this matter (hence I asked my friend for some advice who is also no expert) and would appreciate any input from forum members on this matter. I have asked the EA for some information on the type of insulation and also whether there is any guarantee/documentation available - I'm yet to hear back.
Thanks, Ash
mchu6am4 is offline   Reply With Quote
Old 03-14-2007, 02:10 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by mchu6am4 View Post
Hi,
Thanks, Ash
Not all spray foam is banned.
http://www.powerhousetv.com/stellent...bu_000575.hcsp
But 'Urea Formaldehyde' is:
http://www.dph.state.ct.us/Publicati.../EOHA/uffi.pdf
http://everything2.com/index.pl?node_id=1478821
If that is what is in there....I'd run....
- Build Well -
Old 03-14-2007, 02:34 PM   #3
Thanks for your reply AtlanticWBConst.
After reading you links, I've come to the conclusion that if it was installed more than 10 years ago, then the health effects are neglible and you don't need to worry about it.
What are your thoughts on that?
Ash
Old 03-14-2007, 02:56 PM   #4
concretemasonry's Avatar
Rewards Points: 2,578
mchu6am4 -
If you really want an evaluation, ask you friend if he knows the difference in the effectiveness of the different types of insulation. - Not all adhere and some shrink.
concretemasonry is online now   Reply With Quote
Old 03-14-2007, 03:19 PM   #5
Originally Posted by concretemasonry View Post
mchu6am4 -
I'm really concerned about the health effects of the insulation and not its effectiveness.
Old 03-14-2007, 03:50 PM   #6
I would suggest getting a sample of the insulation and having it tested...That will provide you with the information to find out exactly what it is composed of. Then you can do more research on it before moving forward, or moving away...... before signing anything...
- Build Well -
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
attic knee wall insulation improvments truebaca Building & Construction 1 07-07-2007 11:04 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Insulating 3" Wall Cavity Riddler Building & Construction 5 07-01-2006 08:13 AM
