-   -   Surfacing open decorative blocks (http://www.diychatroom.com/f19/surfacing-open-decorative-blocks-126737/)
lakeresident 12-15-2011 08:19 PM
1 Attachment(s)
We have several outside wall areas that have panels built from open decorative blocks. There are two 12x5 block panels and one 5x5. (~150 sq.ft total) The blocks are 12x12x4 and are set about 1" back into a regular brick veneer wall. There is no lintel across the top. The outside of the 2x4 stud wall on the inside of the veneer appears to be plywood.
We once refinished the interior wall and found that some of the 2x4s had partly rotted.
I have been hoping to find an economical way to seal the walls.
I had quotes on :
- synthetic stucco over the blocks, but even with 1" foam, it would protrude out and be vulnerable to impact damage. ~$3k
- Removing blocks and rebuilding with brick - ~$6k
- Apply cement board and then stucco like finish ~$4k
I was hoping for something less expensive! Maybe there is something I could do myself? Ways I have thought about:
- Pack mortar (or maybe hydraulic cement?) into openings and the parge to form stucco like surface and then paint? Maybe part fill openings with styrofoam pieces first?
- Apply prefinished panels directly to blocks - Maybe Hardie-panels?
Any other suggestions for both DIY and contractor solutions?
joecaption 12-15-2011 08:31 PM
I have just got to be miss reading this post.
Those blocks have open areas in them, and you installed some form of paneling and 2 X 4's without removing them and blocking in that area or framing it in and siding?
So that wall also has no insulation behind the panels and you live in an area where it snows.
lakeresident 12-16-2011 08:11 AM
No that is not how it is. The wall on the inside of the brick/block is a normal insulated 2x4 wall. It has sheathing on the outside surface that appears to be painted plywood (can only see it through the block openings)
The wall has been that way since the house was built by original owner (a contractor) in late 60's. It was originally a garage. We converted the garage to living space about 20 years ago and at that time redid the interior drywall. When wall was open, we saw some rot on 2x4 supports and repaired it and at same time replaced the damaged insulation. We don't get rain into the wall, but if snow builds up, it could melt and enter wall. I try to keep it cleared.
But now, I want to seal those openings.
jomama45 12-16-2011 10:40 AM
It looks like you have a bunch of "screen" block you're looking to cover up.
The easiest & cheapest DIY approach may be to cover them with some form of sheet-goods. Something like an Azek product would likely be easy & last a long time, although it would be expensive I bet.
lakeresident 12-17-2011 04:13 PM
I checked and no Aztek dealer near us. Same for Hardy Panels. (We are in Canada)
Any other suggestions?
