Old 09-07-2011, 10:57 AM   #1
Surface repair spalling chimney bricks.
We have some chimney bricks that are spalling. Cant afford mason repairs right now. Previous owner had covered some of the spalling brick faces with a gray cement/mortar and it has lasted very very well. Trying to figure out what he used. Looks light gray in color, very hard and seemingly able to be put on thin. I believe he ground out the loose brick surface first then applied. It might even just be cement as it doesnt appear sandy like mortar. Presuming its a cement, any thoughts on best type of cement for brick surface rapir.
I know its not the nest choice but no way can I afford professional repairs right now, and whatever he did on those few bricks has held beuatifully for 10 years.
a_gunslinger is offline   Reply With Quote
Old 09-07-2011, 11:14 AM   #2
Super Moderator
vinyl patching cement. Very smooth and very sticky. Sold in any home store or hardware store.
Old 09-07-2011, 11:17 AM   #3
thanks oh'mike. Wonder if that type can be tinted with some of that quickrete coloring has well.
Old 09-08-2011, 07:04 PM   #4
Super Moderator
I doubt it it's a dark gray.
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
Chimney repair: rebuild or repoint? cloud9 Building & Construction 33 09-22-2009 10:12 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
chimney crown repair. gap between flues andy_b General Discussion 4 02-20-2006 12:22 AM
