Supporting A Steel Beam?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2010, 05:18 PM   #1
Ed
supporting a steel beam??
need some advice:
i had an engineer come out and draw up a support beam for a wall i am removing. its going to be approx 15 ft long and 6x6. the plan calls for 2 2x6s under each side. how do i secure the steel beam to the supports???
we were originally thinking using LVL but it was getting too think/deep.
edfromma is offline   Reply With Quote
Old 02-25-2010, 06:10 PM   #2
Rewards Points: 1,016
I have done a couple I-beams - brackets were added and/or holes were made in the beam to lag bolt it to the wood framing.
Old 02-25-2010, 06:58 PM   #3
you could have a couple of tabs/ears welded to the end web to allow for lags into the king stud
The older I get the better I was
Old 02-26-2010, 08:39 AM   #4
Ed
thanks welding isnt going to work for this one.
proposed steps:
run a top plate (2X6) along underside of floor joists.
to connect to top plate: (best option)
1. have them cut holes in top flange for bolting into top plate
2. drill through the top flange into the top plate and bolt
3. use a .22 cal driver and have some fun
is there a bracket or connector I can use to connect the ends of the ibeam to the supports (2 2x6)
Old 02-26-2010, 03:42 PM   #5
Rewards Points: 5,336
Why not have the metal fabricator weld up a "U" shaped bracket that would be bolted to the "I" beam and the double 2x6's.
Another alternative would be to use steel poles and bolt them to both the floor and the "I" beam.
Ron
Old 02-26-2010, 04:15 PM   #6
are there king studs at the ends where the jacks are holding up the beam? if there are then my original post would work
Old 02-26-2010, 09:38 PM   #7
Agreed - this is what I have done. The metal yard that fabricated the beam readily added what was needed to bolt it into place.
Old 03-01-2010, 05:34 PM   #8
Civil Engineer
Rewards Points: 4,940
Not to get too picky, but you (and I) live in a seismic zone with a maximum anticipated earthquake of approximately 6.5, so the code requires design for a lateral force of 0.15g (at least as I recall). The engineer really should have designed the connections for you as well as sizing the beam, since the connections are critical to proper performance during an earthquake. I suggest you ask your engineer to review the connection detail you have apparently had the yard fabricate for compliance with MA seismic requirements.
Tags
load bearing wall , lvl , steel beam , support wall
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 03:55 PM
attaching garage loft support to 12 inch steel I beam lospinoj Building & Construction 4 09-14-2009 01:38 PM
steel beam length otto man Building & Construction 4 07-27-2008 08:11 AM
Steel Beam in Basement Heinz Building & Construction 2 11-10-2007 12:11 PM
Steel Beam or Wood Reinforcement for 2nd floor addition? coralhead1 Building & Construction 2 06-06-2006 01:22 PM
