Supporting Beams For Open Porch Gable Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 12:30 PM   #1
Supporting beams for open porch gable roof
Hello Folks, I'm building a wrap around porch and at one end of the porch, I'll have a gable roof above the door.
The span of the entire gable is 9 feet and the depth from the posts to the house is 8 feet.
In general for each of the beams I plan to use a 3 ply 2 X 10. The outer posts will sit on 6 by 6's with beams coming out from the house and then a beam going across the front. I would also have a ridge beam but don't want to put too much weight on that because of the point load it would create on the front beam in the middle of the span. So will have ceiling joists to take the load to the outer beams.
I need to make sure the beams are solid at the house then. I will open the house up (I've done that) and will run a post down to the foundation.
However I would be attaching the beam right where the header to the wall and rim joist would be. I would need to use a hanger instead of resting the beam on the post.
Wanted to get your thoughts on this. Is this typical for a beam from a porch going into a house. Any concerns with the hanger? I looked around for a heavy duty hanger - but can't find them - where do you folks get beam hangers?
Thanks,
Hick
hick23 is offline   Reply With Quote
Old 08-16-2012, 08:07 PM   #2
Civil Engineer
Rewards Points: 4,700
Simpson makes a wide range of hangers that can handle most anything. You need to compute the shear on the hanger, which is based on the loads and the geometry. Since there are typically a variety of hangers that will fit a given situation, you select the one you need by the load imposed. Or select a hanger that fits, determine its load capacity, and check to make sure you do not exceed the rated capacity. You can get Simpson hangers at virtually any lumber store, or at many big box stores, but the selection at the big box store may be limited. You can also order them on line.
Daniel Holzman is online now   Reply With Quote
Attaching gable porch roof to wall grpie Roofing/Siding 1 02-23-2012 07:28 AM
Attaching gable porch roof to split level wall grpie Building & Construction 1 02-23-2012 04:28 AM
Tied in Porch Roof to Existing Roof - Leaking bharling Roofing/Siding 29 03-08-2011 05:06 AM
Leaking Roof Where House Meets Porch tazmajazz Roofing/Siding 7 08-25-2010 06:18 PM
Adding a gable porch to a pitch roof fjacky Building & Construction 5 08-09-2005 06:56 PM
