supporting in the basement
Removing a structural support post is not that simple, the post was installed as per a design dictating the location, load and span of the beam it is holding, yes the 3 - 2x12 laminated together are a beam. below the post is some form of footing supporting the load from the post, removal of the post and replacing with a framed wall is good intentions, now a footing will be needed below the 2x4 wall (need 2x6 if 2 storeys above) to help distribute the load, the existing concrete floor is not normally structural and can not support the load.
Is it not possible to leave the post in and frame around it, incorporate it within the cavity of the framed wall?
Chris
