Supporting The 2nd Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 06:43 PM   #1
Supporting the 2nd floor
I've got an interior wall that turns out to have once been an exterior wall (which I discovered after removing the wallboard).
It was the gable end of an addition (circa 1940?) to which a wrap-around mud room was added (circa 1965?). The foot print is a 10ft square (circa 1940) within a 17 ft square where the two squares share one, common corner (hence a 7ft wrap-around on two sides). The existing, conglomerated addition has a hipped roof whose joists are supported by a stud wall that was erected parallel to the former exterior wall (t&g siding still intact!).
I want to remove this funky double wall (10ft long) to open up what is currently a 10' x 17' kitchen with two windows into a 17' x 17' kitchen with 6 windows and a double sliding door. (Yes, that's right, the mud room has four windows and a double slider.)
The 1940s exterior wall was framed in the balloon style, and is perpendicular to the 2 x 6 attic joists above (which are nailed to the sides of the studs instead of resting on a plate.)
So-
Can I span the 17' (of which only 10ft are load bearing) with a single, wooden beam? It would have to be a least 8" wide to catch and support both the c1940 joists AND the c1965 joists. But, how thick (deep? high?) would it need to be? 8 x 8? 8 x 12? Or, must I resign myself to having a post at the 10ft point (which is supported by a masonry foundation that must have been reinforced during the 1965 renovation)?
Montague Mike is offline   Reply With Quote
Old 08-06-2010, 07:37 PM   #2
DIY staff
Rewards Points: 7,174
Going to need a picture or two---You will want to get a pro to look this over--
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 06:49 PM
supporting a floor joist havens General DIY Discussions 13 02-16-2009 02:26 PM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 10:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
