Support For Water System - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-09-2010, 05:06 PM   #1
support for water system
originally i was planning to pour a small pad 4'x4' to place a water chlorination system on. the system full will be 1000 lbs. the weather has gone bad and is getting worse. this project needs to be done by monday the day we will move into the house. i'm thinking of securing 6x6's together for a temp. fix until spring. i know that i can do the concrete and protect it from the cold but there is a huge storm heading in. does the 6x6 idea sound reasonable or am i fooling myself? there will be a shed to protect the water system, fully insulated and heated. and would this be considered a temporary structure to the town. or SHOULD i get permits. i really was not planning on permits.
logan1881 is offline   Reply With Quote
Old 02-09-2010, 07:25 PM   #2
Civil Engineer
Rewards Points: 4,568
I have no idea if you need permits, if you are concerned call the local code enforcement officer. As for the support, if the natural soil is decent, i.e. sandy or gravelly, you can certainly support your system by placing 6x6 wood beams in a square, and fill with crushed stone. You need to clear off the snow first, and you should compact the stone using a whacker, but 1000 pounds is a very small load on a 4' square pad, so I would not get too concerned. Plenty of time to pour a footing in the spring.
Daniel Holzman is online now   Reply With Quote
Old 02-09-2010, 08:31 PM   #3
grassy @$$. i would rather have crete but the time is just not right.
Tags
foundation
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 01:14 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 11:06 PM
New To Hot Water Home Heating System Midicat HVAC 2 10-14-2007 09:12 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
