Support For Tire Swing Or Porch Swing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2013, 11:16 PM   #1
support for tire swing or porch swing
We are building an 8' x 8' playhouse eight feet off the ground. Floor joists will be pressure treated 2x6 set 12" apart. Is one 2x6 8 feet long strong enough to support a tire swing or a porch swing hung underneath? If 2 x 6 is not enough support, please suggest what support needs to be installed---we have not begun, so I can add more lumber to order and it can be created without having to remodel. Thanks!
Ewalker is offline   Reply With Quote
Old 05-08-2013, 11:36 PM   #2
Rewards Points: 12,790
Hard to say with being able to see a set of plans, a picture, something so we can see you plan on hanging it.
I would just double up the 2 X 6 in that area.
Ewalker (05-08-2013)
Old 05-09-2013, 09:14 PM   #3
Thank you. Plan is to frame 8 x 8 platform using 2x6 every 12 inches with outside square being 2x10. Down the road want to hand tire swing suspended flat from bottom of platform. Platform is to be about 8 feet off ground so there should be room for a swing. (is that enough of a plan/detail?)
Old 05-09-2013, 09:23 PM   #4
Roofmaster
Rewards Points: 2,172
You are not going to get much pendulum action going with a 5 foot piece of rope. Dont you have any tall trees?
Hanging Porch Swing jakate General DIY Discussions 2 05-15-2012 03:57 PM
Plans for Retrofitting Concrete Porch - Advice? BSponz1 Concrete, Stone & Masonry 1 05-07-2012 09:35 PM
Replacing covered porch support posts yousah Remodeling 4 09-30-2007 01:15 PM
help with support beams on porch falcon802 Carpentry 3 06-24-2006 11:00 AM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 10:33 PM
