Support Pole For Front Door Awning Is Loose - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 11:20 PM   #1
Support pole for front door awning is loose
I live in a rental property and promised my landlord I would look into this issue. There is a wood awning mounted above the front door of the house.
The front of this awning is supported by 2 wooden poles. One of the poles is submerged into concrete, the other pole I just noticed is loose and was never submerged into the concrete foundation. (Please see attached picture).
I am wondering if there is any easy way to secure the bottom of the 2nd wood pole without cutting into the concrete foundation.
techman41973 is offline   Reply With Quote
Old 02-07-2012, 11:23 PM   #2
Get a concrete anchor. Drill a hole in the concrete the same diameter as the anchor bolt. Attach an L bracket.
conspikuous is offline   Reply With Quote
Old 02-07-2012, 11:25 PM   #3
Rewards Points: 13,750
3, L brackets, use Tap, Con screws in the concrete. You'll need a hammer drill.
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
Support pole / beam USAF Retired Building & Construction 6 01-03-2009 06:11 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Support pole holding up over hang... Jshakour Carpentry 4 04-24-2008 09:18 PM
