-   -   Support pole for front door awning is loose (http://www.diychatroom.com/f19/support-pole-front-door-awning-loose-132972/)
techman41973 02-07-2012 11:20 PM
1 Attachment(s)
I live in a rental property and promised my landlord I would look into this issue. There is a wood awning mounted above the front door of the house.
The front of this awning is supported by 2 wooden poles. One of the poles is submerged into concrete, the other pole I just noticed is loose and was never submerged into the concrete foundation. (Please see attached picture).
I am wondering if there is any easy way to secure the bottom of the 2nd wood pole without cutting into the concrete foundation.
conspikuous 02-07-2012 11:23 PM
Get a concrete anchor. Drill a hole in the concrete the same diameter as the anchor bolt. Attach an L bracket.
joecaption 02-07-2012 11:25 PM
3, L brackets, use Tap, Con screws in the concrete. You'll need a hammer drill.
