Support For Garage Foof Sheathing. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 10:58 PM   #1
Rewards Points: 266
Support for garage roof sheathing.
Hi, I believe the roofers used 5/8" CDX sheathing when they replaced my garage roof, then EPDM rubber roofing over the new sheathing. The joists are 2X8 spaced about 24" apart. The also used metal clips at the sheathing joints but they don't seem to do much. The problem I noticed after the first winter is minor bowing at some of these joints in between the joists. I'm thinking the solution is a 2x4 ro 2x6 board across these joints either toe nails in or mounted with joist hangers.
Any suggestions? Will post pics if that helps.
Jim F is offline   Reply With Quote
Old 10-23-2010, 02:07 AM   #2
Rewards Points: 1,092
5/8 CDX, 24" OC ought to be good. If not, your idea sounds good. If there is any concern about the sheathing warping/bowing up, epoxy your 2x4s to the CDX, then nail them. I had this same concern when I built 35 yrs ago, and did what you are thinking of, but I think I laid 2x4s on their side to be easier to nail to through the CDX. I don't recall, but either way I think (THINK) is solid enough, because I bet most houses don't have anything there, and they seem to be OK. j
Old 10-23-2010, 02:31 AM   #3
jlhaslip's Avatar
Rewards Points: 914
I'd be using PL400 to bridge any gappage in the blocking...
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 10-23-2010, 02:46 AM   #4
good idea. thanks. j
Basement Metal Support Post virgolibranyc Building & Construction 4 09-07-2010 04:07 PM
Best Method for attaching decking lateral support getzjd Building & Construction 2 05-19-2010 07:45 AM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 01:12 PM
Moisture on Inside of Sheathing elburritoloco Building & Construction 18 01-19-2009 09:16 PM
