Support Framing Around Ductwork - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 04:46 PM   #1
Hello.
I have a low spot in my basement where I have return/supply ducts approx. 4' wide combined. What is the best material that I can use to frame the ducts out for drywall with the MINIMAL amount of headroom clearance? I have seen on videos some kind of angle the drywall gets attached to but have never seen it in stores before. What can I use?
mfleming is offline   Reply With Quote
Old 12-02-2008, 06:05 PM   #2
Custom Cabinet Maker
my first choice is 5/4 x 3 bridging.
skymaster is offline   Reply With Quote
Old 12-02-2008, 07:04 PM   #3
Rewards Points: 16
they make an "angle" that is used in framing with steel studs but one of them on each side would not hold a 4' peice of drywall up. You will need to use some kind of 2x material under the soffit for support.
ponch37300 is offline   Reply With Quote
Old 12-03-2008, 03:02 PM   #4
with the angle do you have pics or does HD or Rona sell it on their site?
Old 12-04-2008, 02:45 PM   #5
I couldn't find that angle at any of the big box stores. I had to go to a building supply store to get it.
It's super easy to work with, which is really nice.
Garasaki is offline   Reply With Quote
framing around ductwork jcrampton Remodeling 12 08-01-2011 03:31 AM
Failed framing inspection Hope I can sleep tonight!! NJlumberjack Building & Construction 14 01-16-2008 08:50 PM
Replacing support beams Annimal76 Remodeling 1 09-10-2007 11:12 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
