Support Columns For Second Story Roof Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 01:11 PM   #1
Support columns for second story roof deck
I have a walk out roof deck over my first floor bathroom and laundry room. I want to replace the three support columns that hold up the roof over the roof deck along with the rotted wood around the base of them. My question is whether to secure the bottom part of the column to my new floor or support the column below the floor near the floor joists and build the floor around the column when I redo it. If I put the floor(plywood sheets) in first then place the columns on the floor, how to I attach them without screwing or nailing into the roof so it doesn't leak into my first floor area? If I build around the column, I will have a gap around the column to seal off from leaks. Which is better?
MugsynSax is offline   Reply With Quote
Old 10-05-2010, 08:43 AM   #2
Rewards Points: 5,336
Install cleats on the roof that will get inserted into the hollow of the column. Run the roofing up the sides of the cleats like flashing on a skylight. Put the columns over the top of the cleats and secure through the sides, high enough to not compromise the roofing.
Ron
Old 10-05-2010, 09:01 AM   #3
Thank you for the response. Maybe to clarify, the column is actually a 6x6 pressure treated post. There is no hollow part to it.
Old 10-05-2010, 10:27 AM   #4
Okay then. Use a pipe flange with a 2" pipe. Bolt the pipe flange to the deck. Bolt it into framing, not just the sheathing. Drill out the post to receive the pipe. Run the roofing up the side of the post. Install a base molding around the post bottom to conceal the roofing.
Ron
Building roof over deck. 4x4 bracket question? greaserig Building & Construction 8 10-05-2010 04:53 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Roof top deck questions fixeruppers Building & Construction 2 06-30-2009 06:04 PM
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 12:03 PM
