-   -   Support column footings (http://www.diychatroom.com/f19/support-column-footings-6501/)
Gregory 02-14-2007 08:14 PM
I just bought a spec home and the support posts in the basement are only 37 inches from stairs, directly in front. The plan states that they should be 4' 3" from stair and footing under them is 2' x 2'x12". My suspicions are that they are not even on a footing being that the footing on the plan is 39" from stairs.
First question
Is the only way to tell if they are on footing to drill through floor to check?
Second concern: How much footing is supposed to be around post to disperse structural weight from above?
cibula11 02-14-2007 08:22 PM
You will get a more professional answer, I'm sure. But, I would not assume the house would pass inspection if the posts were not buried in concrete.
AtlanticWBConst. 02-14-2007 09:05 PM
First question
Before you panic...please realize that what is on ink in plans is NOT always what will work out with wood, steel and concrete on site....
This is a reality of building, construction and remodeling....
Because it says one thing on paper, do not assume it is that way or should be that way on site.....
