Support Beams Under A Shotgun Style House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 10:05 AM   #1
Support beams under a shotgun style house
I am needing to know the size of beams I will need to replace the main support beams that run vertical under the house and how to do it? My husband is very experienced in concrete and woodworking so just some detailed info would be great.
Jcarr30 is offline   Reply With Quote
Old 07-10-2011, 11:07 AM   #2
NACE Coating Inspector
mustangmike3789's Avatar
we will need a little more info and pics if possible. what size beams are you replacing? what are they made of, wood or concrete? why are you replacing them?
mustangmike3789 is offline   Reply With Quote
Old 07-10-2011, 11:32 AM   #3
Rewards Points: 150
As MustangMike mentioned, more information is necessary; specifically measure the span from exterior wall to the center support (girder) and let us know if it is a one or two story house (and if it is a two-story, if the 2nd floor has a bearing wall that transfers a load down to the girder you are replacing, also mention what the use of the rooms are.
TheCamper is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-28-2011 11:10 PM
12V Shotgun Lock, with Keypad and Battery Backup in House? rdiggidy Electrical 12 01-28-2011 02:08 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
support beams garnet Building & Construction 2 04-22-2008 08:08 AM
