Support Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 07:01 AM   #1
support beams
how far apart support beams in basement of 2 story house
jflatt is offline   Reply With Quote
Old 03-13-2012, 07:19 AM   #2
Thread killer
Rewards Points: 272
Depends
Canucker is offline   Reply With Quote
The Following User Says Thank You to Canucker For This Useful Post:
framer52 (03-13-2012)
Old 03-13-2012, 10:05 AM   #3
Rewards Points: 626
Well that is a very opened question Depends? What is the span? what is the live load? what is the dead load? Etc...
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Old 03-13-2012, 02:19 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
As you can see from above....more questions than answers....
Are you meaning real support beams supporting floor joists or are you calling the floor joists support beams? Pics would help.
Normally, floor joists are 12" or 16" OC (On Center). If these are then attached to support beams, the distance between the beams would depend on the loading above, the span of the floor joists ad the spacing as well as the depth of the floor joists. A 2x12 floor joist can span a longer distance than a 2x8....
As you can see....lots of questions....
ddawg16 is online now   Reply With Quote
Old 03-13-2012, 09:53 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
it also depends on what type of floor system your using.. what the wall layout is going to be.. to many variables to answer such a vague question
woodworkbykirk is offline   Reply With Quote
Old 03-13-2012, 09:59 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
2-3/4".
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Concrete piers in 55 gal drums support I beams DeanPk Building & Construction 13 07-05-2016 08:17 AM
Laminated support beams for 25 foot long footbridge. fifty7flash Building & Construction 7 10-09-2010 05:03 PM
Need advice on support beams in older house Vlmrdm Building & Construction 1 05-03-2010 12:26 PM
Replacing support beams Annimal76 Remodeling 1 09-10-2007 10:12 AM
where to get support beams elementx440 Building & Construction 5 03-21-2007 05:19 PM
