Old 12-10-2011, 10:10 AM   #1
support beam
I am building a mezanine in my garage workshop for storage of misc stuff. I will be 16'x4'. What size should the 16' beam be? Lvl or solid???
yankfan7 is offline   Reply With Quote
Old 12-10-2011, 10:21 AM   #2
"Nail-Bender"
support beam
Hi!
"yankfan7"
More information is required.
rossfingal
rossfingal is offline   Reply With Quote
Old 12-10-2011, 10:24 AM   #3
support beam
What info do you need?
Old 12-10-2011, 10:39 AM   #4
Civil Engineer
support beam
Sizing of a beam requires estimating the loading on the beam. In your case, you state you are storing "misc stuff", so you need to estimate the weight per square foot of the "stuff". Just to get you started, light "stuff" like bags of styrofoam might weight up to 10 pounds per square foot. Heavy stuff like books or magazines weight approximately 50 pounds per cubic foot, so if you are planning to stack the "stuff" a foot high, that would be about 50 pounds per square foot, or if you were planning to stack paper 2 feet high that would be 100 psf. If you are planning to store machinery, tools, steel pipe, or similar "stuff", you could easily get up to 150 psf.
The size of your beam will be determined by the loading of the "stuff" you are planning to put up there. It will also be determined by the fraction of the total area of the loft to be supported by your beam, which will be determined by the geometry of your mezzanine, which you can show us via a detailed plan.
So once you specify the loading and the geometry, it is possible to size the beam.
Old 12-10-2011, 10:42 AM   #5
support beam
Lets say it will be 50 lb per sq ft. It will span between two walls and all along a back wall,
Main structural support beam HELP!!! Daniel048225 Building & Construction 34 02-17-2011 12:35 AM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
